My mondeo went into garage to have the near side front bearing replaced. It's an 06 with 174,000 odd miles so done well. I did both rears last year but the fronts can be problematic so left it to a garage.
First bearing was fitted. Lower wish bone worn so authorised its replacement as well. On test first bearing was loose so replaced. Garage noticed damaged threads on CV joint so replaced it at their own volition as they may have caused it.
Test drive pulsing brakes on light application. Checked all fittings but definitely on the near side front. Garage replaced ABS sensor no more pulsing. However ABS lights go on shortly after code read and indicated no signal from near side front. Garage suggests dodgy connector /cable from sensor to wiring loom. Google search suggest this as well.
They did not charge for the ABS sensor but it needs to go back in to fit the ABS issue. I am thinking that this is their problem as it was fine before they started work on the car. Should be a simple swap from on side to near side of sensor and cable to establish fix and then replace. Happy to let them try and fix but am I right that this should be without charge to me? I would welcome your opinions.
