I moved into this flat some months ago and I really couldn’t tell you if these cracks have appeared over time or were already there. As I’ve been pretty oblivious to it except a couple which I noticed on the ceiling.
I haven’t decorated the walls at all since moving in. Mostly because I cba.
But the paint that was previously applied before I moved in… seems to have been the thickest paint possible?
Odd bits just looks gloopy and as if it was caramel which slowly dried.
So I assume it’s to do with that.
I do mostly believe these are nothing to worry about. I don’t think the whole flat is about to collapse or anything of that sort.
I just want to know what or if it is something that needs more attention.
Ground floor flat.
I tried to capture photos of all of the cracks. They are in every room and I took a photo of what looks like previous repair was made to the crack / slight texture difference across same line/path as the crack connects to. Reoccurring issue? Underlying issue?
All of the cracks do follow the same direction as the others. Well the walls *all go north to south and the ceiling cracks all go east to west.
Pictures uploaded here https://ibb.co/album/tBSqMM
Ground floor flat.
