I'm about to plasterboard an old outhouse, ifs got 3 external walls (single brick) and I want to dot'n'dab thermaboard on to it (polystyrene backed plasterboard).
The walls have been glossed a few years ago and I'm planning on scratching the gloss so the adhesive can grip to the wall. I don't want to have to batten the wall the fix the boards to the batten because I don't want to loose too much space (the thermaboard already has 50mm of poly on it).
Is this an acceptable way of fixing thermaboard? does the adhesive fix to the polystyrene?
I will be fixing some wall units to it once its been plastered, but will use long fixing and go into the brick.
Thanks in advance,
Thanks in advance,
