I have spent the last few months insulating my house using 27mm thermal board on the interior walls as it is only a single block house (built 1930's) I've now got to the bathroom and am wondering what the best material to use on the walls is. I want to tile most of the walls in the bathroom but I also want to insulate the inside/outer walls as I have done throughout the house so far. I have used dot and dab and nailable plugs on the other rooms but as this room is going to have lots more moisture I don't think this method would suffice, does anyone know of any thermal board that is moisture resistant? or would screwing batons and fixing the thermal board to the outer walls and then applying wedi board over the top be better?
thanks in advance
thanks in advance
