Thermal plasterboarding solid wall/internal insulation - advice please
20 Mar 2018
First time posting here, I have taken all the plaster off on the external solid 9" walls (1930s house) and now want to insulate and redo them using celotex 37.5mm thick 2.4mx1.2m plasterboards. I have heard many stories about damp and condensation issues caused by internal insulation. Do you guys think think with above, my walls could suffer from damp and condensation issues?
The walls are completely dry but it seems like the existing brick jointing material is plaster or just sand, as it starts to come off as soon as you poke it with anything, so I have removed some of the jointing and will repoint with cement mortar before adding the plasterboards. Aslo, the only issue I have with the wall, is on the plastered (maby non breathable) outside walls of a previous walking wardrop (1.5m*1.5m) in the main bedroom, they have a lot of damp patches on them and condensation too. I have had the small windows open in that room for the past 3 months and the damp patches are still there. Condensation drys off when all the windows are opened up after few hours.
I would prefer external insulation but that's out of my budget currently.
Your advice is appreciated.
Insulation does not cause condensation in any form , must be listening to jakanory? Would use 50mm + insulted board 37 is a bit mean.
Whats on the exterior of the damp area?
Just bare bricks. Although I did forgot to add that, the roof has some holes in it that hasn't been touched for years (I found this thanks to google streets view history) also a roofer told me the gutters need changing too as they are the old cast iron ones (all pending repairs). I have bought the house 3-4 months ago.
The 50mm is too thick and expensive, it will almost cost double the 37.5mm. The internal insulation is a short term solution and will externally insulate it in the future. Thanks
The roof and gutters could be the source of all your damp, need fixing before any internal work.
I insulated my walls using similar method and room was much more comfortable. Suggest use expanding foam to close any gaps and foil tape so that warm air can't get past insulation to the cold wall and condense.
It will if warm, most air gets behind the insulation and onto the cold wall.
