Hi, I an insulating my attic and need to put 40mm of kingspan inbetween rafters and an extra 60mm under the rafters. The queston is because with two seperate boards I would have 4 layers of foil rather than just two layers of foil if i was to use a 100mm board for instance. Would 4 layers of foil increase the thermal value. The reason being is that I was thinking of just having the 40mm in the rafters and then the insulated drylining board at 60mm under the rafters. Though i think two foiled boards would be better.
