hi... first time ive seen this fault but my thermal store has sprung a leak... no corrosion, no splits, nothing... its a 2001 model of the telford tornado 2, has the two pressure relief valves in the top with the pressure regulator, along with the expansion vessel (all enclosed )... the 'leak' is so that the entire top of the casing is full of water (submerging all the valves and exp. vessel (the cylinder being a foot or so shorter than the outer insulation and casing...the insulation is all thats keeping the water in!!!) my only thought can be the expansion vessel has failed but why leak water if its sealed?... i took the vessel off and recharged it and noticed the top of the vessell was virtually full of 'orrible brown rusty water, but the pressure didnt immediately fall off like a ruptured diaphram would suggest... my head is bleeding with all the scratching going on atm so any help would be appreciated
