Thermal Store problem after replacing radiator
28 Jan 2006
I have a 9 year old system, with seperate boiler. After changing a rad and cleaning out the system, I have the following problem:
hot water is fine and the store heats up well.
When the Central heating pump comes on, the tank makes 2 noises like air is expanding or something, (sounds like a clunk clunk) then the same when the pump shuts off. Looking at the top up tank when this is happening I can see a small amount of hot water from the store expanding back into the tank.
I have bled the rads and am now out of ideas.
thanks
Mark
Is it a motorised valve which is making the clunk and letting air through?
Hope you have loads of inhibitor in that tank...
No Chris, its comeing from the storage tank itself.....it sounds like the tank is flexing in and out briefly.
