Thermecom Oil Fired Boiler problem
13 May 2016
The Thermecom oil fired boiler serving the central heating system (both underfloor and radiator) fires up for five/ten minutes at various stages in the day without the heating on and the thermostats set at minimum? Why is this? Thanks.
Check that the heating motorised valve isn't sticky and as it has a micro switch that switch on boiler when heat is calling for.
Daniel.
