My thermecon 40/60 oil fired boiler doesn't even try to start up after the Horstmann Channel Plus timer lights up, any suggestions
What other controls do you have?
I did suggest checking for live feed at boiler before lifting clock off base plate. Hardly pulling it apart.Errhhh have you made sure the boiler overheat thermostat has not tripped before you go pulling your new clock apart??? just a thought!
Fair comment oilhead..no offence intended!! however it is best when fault finding to start at the end of the elctrical circuit and work back i.e. burner lock-out overheat stat trip, swl to boiler, feed to circ pump M/V's opening
Room Stat Cyl stat Programmer.
