I have an old Baxi Bermuda 552 backboiler that just powers a one pipe radiator system and a fire.
I have a Randall 103 timer switch and a Satchwell TLX2259 thermostat. The problem is there is no wiring at all going to or coming from either thermostat or timer.
It has all been removed The only visible wire is a length of 3 core 3amp cable coming from the boiler which i guess is for the spark generator and a length of wire coming from the pump?
There is also a switched fuse spur near the timer which i assume is where once the power source came from.
I can access all parts quite easily.
Can anybody advise on what wires need to go where. Do i need connector blocks etc.?
Any advise or simple wiring diagram would be appreciated thanks.
