Thermostat change - Honeywell to Salus RT300RS
29 Feb 2012
My existing Honeywell has 3 wires connected to it. L, N and heating load. The new Salus I have bought shows 4 connections L, N, Comm, NO (Normally Open).
So the L and N I can deal with but which of the other two terminals will the heating load wire connect to? I would assume the NO, but will that be connected to L when the unit switches to heat demand?
My system has:-
1 x boiler
2 x zone valves (one for upstairs heating and one for downstairs heating)
2 x room stats (one upstairs and one downstairs)
It is the downstairs one that I want to change out as it is hidden by wall hangings.
My system has:-
1 x boiler
What model is the honeywell thermostat and what model is the Salus thermostat please?
My system has:-
1 x boiler
The Salus is an RT300RF and the Honetwell is a T6360B.
Thanks for your help :D
My system has:-
1 x boiler
Ensure the 230v link in in place BEFORE you wire this up, (it can be removed for volt free applications).
LINE - Live conductor (red / brown) connects L (top middle terminal) COM
NEUTRAL - Neutral conductor (black / blue) connects to N (bottom middle terminal) N
Switched Live (your heating load) must have brown sleeving on to indicate a live conductor. Connects to SL (top right terminal) NO
