A mate of mine has a Honeywell CM907 programmable thermostat which makes my Horstmann HRT2 look very inadequate!! Besides that, the HRT2 might as well be replaced with an on/off switch for all the use it is.
I have a BAXI Combi 105 HE boiler which has a mechanical timer but I want to put the boiler on constant and use a 7 day programmable thermostat like the CM907. However I believe this is battery powered with two wires from the boiler whereas the HRT2 is mains fed with three wires (according to the spec sheet i've read).
So, my question is: Does anyone know if the CM907 is compatible with my setup OR can anyone recommend a suitable replacement for the HRT2 with similar features to the CM907?
cheers
Adey
cheers
Adey
