As this is primarily a thermostat question, I wasn't sure whether to post it in Home Automation or Plumbing and Central Heating.
Apart from the central heating radiator, there is a 2.0kW flush-fitting, wall-mounted fan heater in my bathroom. The fan heater is simply controlled by a ceiling mounted, corded on/off pull-switch, although the circuit is also interlocked with the bathroom lights, so when the lights are turned off, the heater turns off.
I have been unable to train my children to switch the fan heater off once the bathroom has warmed up and they leave it running continuously wasting electricity. I therefore intend to fit a tamperproof thermostat so the heater will turn off before the bathroom reaches gas mark 6.
My question is which thermostat to buy; bi-metal or bellows electro-mechanical, or electronic?
I'm tempted to go for electronic as the bathroom will be steamy at times and this might corrode the bi-metal sensing assembly.
Two thermostats that I'm considering are:
1. Honeywell T6360B1069 (Bellows temperature sensing mechanism).
2. Horstmann HTT4 (electronic TPI control).
Does anyone have experience of either of these thermostats, or is there another thermostat that might be better for my application? Although I don't need TPI (Time Proportional & Integral) control, I think it should work OK with the fan heater.
Thanks,
______
Razoo
Thanks,
______
Razoo
