I'm going to flush my cooling system on Fiat Scudo 2.0jtd van (2004) at the weekend. I have no experience of modern thermostats, and I believe the stat on this van has a rubber seal that fits around the edge of the actual stat.
Does this rubber ring seal also form the seal between the stat housing cover and the block, or will I need a paper gasket to do this?
Also, does anyone know if the rad is likely to have a bleed plug at the top? There's one on the stat cover, but not sure about the rad itself. The coolant reservoir is the highest part of the system, so I don't suppose there should be much problem with air if I leave the cap off with engine running after refilling.
Another thing - the coolant in at present is red. Will the Scudo be OK with blue, as I have lots of that in the garage?
Thanks for any advice.
