- Joined
- 21 Nov 2021
- Messages
- 3
- Reaction score
- 0
- Country
Hi, I'd be really grateful if someone could help with this. I bought a Danfoss TPone-B to replace a very old dial thermostat. Thought it would be simple but I was wrong. Boiler is and Oil, Worcester Greenstar Heatslave II recently installed by previous house owner
The existing Drayton thermostat is wired into the switched socket supplying the boiler. Three terminals are used in the thermostat - N (blue wire) L (brown wire) and CALL (black wire).
The new Danfoss has COM (COM), OFF (NC) and ON (NO)
Can anyone confirm which terminals I need to use on the Danfoss please. Given that it battery powered and I think the old one required mains I am reluctant to use trial and error on this.
The cable to the boiler has 5 cores, the usual 3 plus black (fed to thermostat CALL) and grey (fed to thermostat L). When the double pole switch feeding the boiler is on there is 250v at the live (L) terminal in the thermostat
I've tried pasting images but they aren't showing for some reason
Any advice on this would be appreciated
Many thanks in advance
