The house we bought has a British Gas 532 Boiler (WB i think) wall mounted behind a wardrobe front in a bedroom, controlled by a British Gas PT2 thermostat mounted on the wall on the landing.
It drives me mad !
Once the house gets cold and you turn boiler on via the thermostat, it develops a mind of its own for the rest of the winter. We might turn it on for a couple of hours when we get home from work, then it will go off a few hours later. Thats fine, but even though the temperature hasn't dropped it'll come on again at about 11pm and keep pumping out heat until somebody wakes up sweating their bits off in the early hours, and goes and turns it off.
In the morning we get up and it's freezing but the heating hasn't kicked in.
It's driving me potty.
I've read the manual, which is no help whatsoever (and incidentally talks about it being wireless - but ours isn't).
I just want a programmable timer, so i can tell it to be on at given times, and more importantly stay off the rest of the time.
Can anyone help with the best (easiest and cheapest) way to switch over to a programmable timer?
Thanks in advance of sharing your knowledge.
It drives me mad !
