I am looking for some advice (surprise surprise) on fitting a new heating/hot water programmer.
My current programmer (Danfoss FP715Si) has been playing up for a while so I decided to replace with Honeywell Y9420H Sundial RF² Pack 2. The pack includes new Programmer as well as Wireless Room Thermostat which connects directly to the programmer.
I did some checking on online instructions and it appears the new Honeywell Programmer is wired exactly the same as the old Danfoss. So programmer wise I can clip new one straight onto the old back plate (if I've worked it our correctly?).
My issue is that the current system already has a wired thermostat. However, I decided to get a new Programmer with wireless Thermostat as the current wired thermostat is poorly positioned right by the front door so doesn’t work well.
The part I’m confused on is how to disconnect the existing wired thermostat.
You can see the Installer Instructions here - http://www.honeywelluk.com/Documents/Installation-Guide/pdf/Sundial RF² Pack 2 - Installer Guide.pdf
Section 1.7 mentions removal of existing wired thermostat. It then says about making some minor changes at the 10-way junction box. However, I am unsure whether I have a S, Y, C or W plan and the junction box next to the tank is just a basic 8 way connection block not 10.
Having taken the cover off the existing wired thermostat it seems to just have a Live (Red), Neutral (Blue) & CH On (Yellow) connection. However, when I look at the junction box there are a few red, blue & yellow wires.
Can anyone advise how I should proceed?
Pictures below if helpful.
Thanks,
Luke
View media item 68603 View media item 68604
Thanks,
Luke
