Hi all
I would greatly appreciate any advice on the following problem.
I have just moved into a new home, which has had a newly installed Ferroli Optimax HE Plus 31C combi and a Timeguard TRT035 Battery Powered Programmable Room Thermostat.
The problem seems to be that the thermostat won't activate the boiler. When the room thermostat is manually adjusted to the maximum room temperature it doesn't activate the central heating and on the automatic settings it likewise has no effect.
I contacted the seller of the house who told me that the central heating definitely works as when the boiler was installed the engineer fired it all up so that he could balance the radiators. However, they said the thermostat was fitted a week later and as it was the middle of summer they never checked that it worked. I think they got a family friend to wire it up, so my assumption is that it's wired wrong.
Does this sound like the right conclusion and should a boiler engineer or an electrician be the most sensible choice to call out? Or is it something I could have a go at myself? I have looked at the wiring diagrams in the boiler manual but they look very complicated to me and I'm worried about potentially damaging the boiler irreversibly if I was to fiddle around myself.
Many thanks
Steve
Many thanks
Steve
