Hi everyone.
Two really daft questions!!!!
1. We have a digital thermostat on our wall. On our baxi boiler we have a knob with setting 1-6. If you turn the knob to the lower numbers you can bring the heating on. Is this because it also acts as a thermostat and if so, should we have it turned right up so it doesn't override what ever setting the room thermostat is at?
2. Our room themostat is set at 19c, we did try lowering it to 18c but it took nearly all evening before the digital thermostat dropped the 1c to turn it on. Is this normal? I thought as the rooms felt cooler then quite quickly the thermostat would show a drop in temperature. Maybe 1c for a digital thermostat is fairly significant.
Hope the above makes sense, any help much appreciated.
Cheers Zeb.
Cheers Zeb.
