Hi all,
following my lack of hot water pressure and newly replaced nrv, i decided to update my bar mixer as the old one was looking rather tired.
However, having had the thing on and off the wall about 5 times, i cannot get it to stop weeking completely.
I have used lots of ptfe on the offset connectors but the hot has to be backed off to line up with the cold and now it will weep from behind the chrome plate.
Also, i have filters that sit inside the end of the offset connectors but the instructions also say to use the supplied washer/ filters inside each inlet on the mixer. When i do this there is no way i can get the thread to go on enough to stop the cold spraying everywhere. I noticed that the old bar didnt have a seperate washer inside the inlets either.
I would appreciate any advice and a link (if poss) to the best washers to use inside the mixer inlets please?
Many thanks
Sunil
Many thanks
Sunil
