Hi ,
I have a cascade thermostatic bar shower , which is fed by a twin supply 1.5 bar pump with decent pressure at shower head . The problem I have is water temperature does not get quite hot enough . I have tried adjusting the override for hot control (even removing it) but still not getting there . The cartridge appears to be working as it moves from very cold up to hot , well nearly hot ! Hot water cylinder is set to about 52 - not sure if this is actually hot enough , but it is at that as the water coming from taps is pretty hot . Any advice would be most welcome .
thanks
thanks
