- Joined
- 5 Oct 2013
- Messages
- 54
- Reaction score
- 0
- Country
I’d really like a Bidet for handling the old claggers, but don’t have room to install one. Luckily, I see there are WC pans available with a Bidet Nozzle built in!
So I’m opening a discussion for the following Harebrained, Heath-Robinson (Not Dan-Robinson) Mechanism:
1. Boiler water is fed to TMV set to say 35 degrees
2. Then supplied to TMV reversed in direction, set to a lower threshold (say 30 degrees).
3. When combi first fires, and supply is still cold, water gets diverted to the cistern (Via the normal hot intake of the TMV)
4. As the water warms up, it gets diverted to the sphincter-nozzle (TM).
• The Close-coupled cistern is set with a low water level suitable for No. 1’s
• When the Bidet is used (before flushing), the initial couple of litres of diverted cold water from the boiler, top the cistern up ready to give a more sizeable flush for No. 2’s.
• If too much water is dumped into the cistern, then it overflows via cistern’s internal overflow into pan.
Discuss!
I’m thinking that an In-Pan Bidet is not a thing that water companies are too happy about; so would require at least a double check-valve somewhere, or an air-gap separated connection.
I am aware of the availability of Bidet Seats with built in electrical water heaters for fitting to normal toilets etc, but many of these are cheaply engineered in China, and 240V + Water + My man vegetables sounds like a risky combination!
Discuss!
