Thermostatic Mixer Shower Installation Question (Connectors)
24 Sep 2006
Berkshire
Having problems tightening the long thread straight inlet connector fitting into the wall elbows that I've fitted.
See Page 6, Fig 7.
http://www.tritonshowers.co.uk/wps/...s/resources/file/ebd4710c847d952/2180430B.pdf
I can only hand tighten the fittings and don't want to grip the threaded section with mole grips etc as I reckon I'd damage the threads.
Any advice from anyone who's fitted something similar in the past on how to tighten the fittings into the wall plate elbows?
Tom
can't really see form diagram you pointed to, but is the internal of the long thread inlet got flats in it to take a rad spanner or the like?
Threaded retainer not supplied but the internal of the long thread do have flat areas that look like they take a very large hex key.
I found that a 20mm wood spade drill bit fits neatly but I don't want to try and tighten it with the wrong tool! :eek:
Max size I can find in a normal set is 10mm, obviously not big enough - hence I presumed there must be some other tool in a plumbers kit bag that would do the job of tightening the connector. :cry:
How about a rad valve spanner? I use a Rothenburger ratchet rad valve spanner which has various sizes built on the shaft, going from small to a lot larger. Dont know what exact sizes are but I wouldn't leave home without it ;)
Well 3/4" is about 20mm so it seems like I need a 3/4" radiator hex key then - time to pay a visit to the shops!
Thanks for the help.
