Hi i want to install a shower valve i got told i can just tee into the hot and cold going to the taps but at college they tell you to take hot from cylinder and cold from cold water cistern...Which is correct and if it is the one which was told at college how do you actually do it...
Do you just tee into the pipe from the cylinder going to hot taps and do you just tee into cold feed pipe comeing from cold water cistern
thanks for any advice
