A few days ago I needed to turn the hot supply off to change a tap valve and noticed that even with the hot supply from unvented switched off, water was still coming out of the hot tap (albeit at a reduced rate). I've done this previously and the hot would always trickle to a few drops after a few seconds.
I've now narrowed this down to one of the thermostatic mixer showers we have - if I isolate it, the hot shuts off as expected to all taps. I've read threads previously where something similar happened and the solution was to replace the thermostatic cartridge. Given it's concealed behind a wall, I'd like to understand if this is the solution before I call someone in to replace it. The cartridge alone is £55 and I can imagine it'll be a bit of a job as I remember the installer plastering behind the metal plate hiding the valve (!).
Is the cartridge likely to be the culprit? Are there not non-return valves fitted precisely to stop this? The shower valve is a Pura Bloque listed here:
https://www.ukbathroomstore.co.uk/p...cealed-valve?gclid=CP_E1sXbptACFWYq0wodfQIN7A
