I have a thermostatic mixer with female 3/4" inlets and outlets on it. I can find the male 3/4" push fit flexible fittings on Screwfix but not the female ones or any female to male adapters.
Am I missing these somewhere? Anyone know what to do?
Thanks for both of those suggestions... only problem is I need flexible connectors any ideas where I can get a flexible tap connector, push fit one end, female 3/4" on the other?
As I understand it, the tiles will sit over the mixer itself and be covered by the metal plate and control knobs.
Somehow this needs to fill my bath tub, so would I use pushfit/copper behind the wall, then use flexible outside of the wall? If that's the case what you've suggested in your posts above will do the trick
i would never use flexi or pushfit in the wall or behind somewhere you can't access easy.
i would use copper in the wall and to feed the main shower head and down to the bath.
you can use a flexi on the last section maybe to join the bath filler to copper where it exits the wall if its a overflow/bathfiller.
but i wouldn't use in the wall.
