Thermostatic Push Button Bathroom Shower valve
8 Nov 2006
London
Dear All
Has anyone had any experience good or bad of using a Bathroom Shower Valve Thermostatic Push Button 3 Outlet type?
One I am thinking of is Harbour Push Button Triple Outlet Square concealed shower valve with life time guarantee?
Also using this valve how do you control the flow rate of water?
Many Thanks
1. What does a "lifetime" guarantee mean - your life or the life of the shower (in which case who decides what that is?)
2. It says it requires 0.2 bar minimum, to work a single outlet. That would suggest it requires 0.6 bar to work 3 outlets, but the web site recommends 3 bar. Something doesn't add up.
3. The web site gives no indication of flow at any given pressure.
4. You'd need to ask the supplier how flow rate is controlled.
5. If you do speak to them you might want to ask about the availability of spares.
