Thermostatic Radiator Valve Not Working?
14 Jan 2020
We couldn't turn the radiator off in the bedroom, so I bought a new valve (Pegler Bulldog Gen2). I fitted the sensor with 5 in the window and turned it to 0, but this doesn't work either. Am I missing something or do I need to replace the valve body as well? Btw We're in a hard water area.
As suggested, check that the valve pin moves, if it does then unless the TRV head is the same as the one that came off of it then it may not work. Not all TRV heads are the same, the internal rod may not move far enough to depress the pin fully.
