Hi, I so hope someone can help me. Sorry for the length of this post but I'm at my wits end!
My bathrooms being done out right now. I chose and bought the shower, Mira Stylus and now realise that it's not really suitable for my water system. The manual states the pressures should be nominally equal where as my hot is gravity and cold is mains. It also states that it is suitable for 0.1bar pressure and anecdotally works well even at this low pressure.
I need a solution fast.
Now, from my research there are a number of options
1) the best solution: take a supply out of the cold storage tank
Pros: Equal pressures
Cons: My bathroom fitter isn't comfortable doing this. He looked at the tank and said it was galvanised or something. I know this isn't ideal but we're too far down the line to change now and he's doing a great job in all other areas!
2) fit a pressure reducing valve on the mains cold.
Pros: Cheap
Cons: They only seem to go to a minimum of 1 bar, whereas I reckon the hot is at about 0.25 bar. I've seen some that go to 0.5bar but none seem available from PTS, plumbcentre etc.
3) fit a pressure equalizing valve
Pros: these seem to balance out at 0.2 or 0.3 so should do the trick
Cons: None seem locally available. Pricey
4) choose a different shower!
Pros: Get rid of this headache
Cons: What to get instead? I like the Stylus, I want the Stylus!
Any ideas, has anyone successfully achieved option 2 or 3? These are the two I'm drawn to the most. My bathroom fitter thinks the PRV should do the trick but we're really not sure!
Any advice would be really gratefully received believe me! I probably need to make a decision tonight due to bath fit-out schedule.
I'm in Leeds.
Many Thanks,
Ezman
Pros: Cheap
I'm in Leeds.
Many Thanks,
Ezman
