We have a fairly low pressure gravity fed system (~1m head) and recently had a new thermostatic valve fitted. Since then the shower is acting quite strangely,
Sometimes takes 1+ minute for water to start flowing
Sometimes cuts out when changing temperature
Prior to having the new valve installed there were no issues other than a slightly weak shower. The previous valve was the one installed when the house was built ~ 12 years ago.
We've been advised a few different things, but no-one seems sure of the reason why this is occurring. Low pressure or a stuck check valve seem to be the main suggestions so I am wondering what the best solution might be.
Remove the check valves (we do not have a combi and have been advised this is the main reason)
Change to a manual (non thermostatic shower valve)
Install a pump to increase pressure
Install a combi-boiler to increase hot pressure (not sure this will increase pressure? Boiler is downstairs in the kitchen ~4m below shower head)
I appreciate any thoughts on it, this is driving me up the wall since no-one seems sure of why it's happening and how to resolve it. I would just like to get it resolved no matter what the solution!
Tom
Tom
