I ‘m hoping someone can give some advice.
I have recently had a thermostatic shower panel fitted, fed with its own hot and cold supplies (so not shared) from the loft above, via a 2bar Salamander pump in the airing cupboard.
The cold comes from the storage tank, the hot via an Essex flange in the hot water tank. Distance from the pump to the back of the shower panel is around 9 or 10 metres. As the pump and panel have 15mm connections, there is around 2 metres of the pipe run in 15mm the rest is 22mm.
So its all pretty conventional stuff. There is nothing in the pipework other than gate valves.
The problem is that the shower panel is a real pig to “get going”. It offers a monsoon overhead shower, body jets or a shower hose. It never starts on the overhead shower or body jets. As a minimum we have to drop the attached shower hose into the shower tray and that generally gets it going, however on a couple of occasions I’ve been down on hands and knees sucking at the hose to prime it.
A couple of thoughts I’ve had are around the distance from pump to panel and the fact that its being top fed. Also the rating of the pump, as I gather these panels can operate on up to 5bar feed.
Any help will be welcomed!
