ok a while ago i asked which was the best type of shower for my boiler, that being a thermostatic one with my vaillant eco pro 28 combi boiler.
The shower I chose was a Cascade Manila surface mounted thermostatic shower.
This has now been fitted,but i have a problem with it.
It is connected by the hot n cold pipes (Obviously i hear you say, but im just stating
) when the shower is turned on it is running warm and i see the boiler kicking in, bear in mind that the boiler hot water temp is set to 40C.
The shower temp is on the minimum, and the factory setting inside hasnt been touched.
If the temp bar is raised to make the shower hotter, it seems like the shower is pumping more cold water through and the boiler lights go out ( the boiler isnt off but its not heating the water as though its not needed)
If the temp bar is put back to the minimum then the boiler kicks in again.
I initially thought that the hot and cold feed pipes had been put on incorrectly but then i was informed that the shower bar has a red and blue marking on it and the hot is on the red one and cold on the blue.
Has anyone any ideas at all please ?
