I have fitted a new Mira Thermostatic Atom shower (large fixed head with diverter). The temperature is just warm, not HOT. I have adjusted the temperature to max behind the temperature handle as the instructions.
Every other Hot outlet in the house gets very Hot. The pressure everywhere including the shower is good.
I have read a reason could be that the boiler just can't heat the amount of water the shower needs quick enough. Would reducing the flow and/or pressure on the Cold feed make the shower hotter? Would I use a Gate Valve? But I saw these should be used fully open or fully closed.
