boiler classic ff250-boiler goes on/off every
minute roughly pump keeps running but romstat and cyl/stat dont reach set point
even when run seperate any help appreciated
water does get hot after a while/ one rad in hall way gets fairly warm
others virtually nothing/pipes to rads are warm but seems to end there
have drained and filled afew times.sounds at times as though their is air
in system around the boiler. property is/bungalow with cylinder/pump in
the loft dont know if this is any help. thanks for your help.
