Thick laminate and hollow door
30 Mar 2010
Gwent
Fitting thick laminate in the bathroom this weekend. Forgot about the door.
Its a hollow cheap door so I guess Im limited in how much I can saw off the bottom? Is 1 inch about right - if so I 'might' be OK.
Any way around this? Is there any way to remove the bottom bit completely, saw the frame bit, then somehow put this bit back in?
I'm guessing having no bottom bit with just a hole/hollow gap would be not good?
Other alternative I guess is new solid door but, of course thats a lot of hassle.
I have done it in the past and just glued the bottom insert back into the door.
Hang on....if the door fitted OK before, and now you need to take off an inch, that suggests the new laminate floor is over an inch thick.....have you laid it right?!?
Not laid it yet but its not as thick as I though. I think we'll be ok.
dont forget you need around 12mm gap under the doorv to allow the extractor to work efficiently
Thin doors have a 20mm timber in the bottom, best to cut this off completely , plane off door panel to the offcut and glue it back in bottom of door.
