I am building rear extension.
Walls will be double cavity walls 30cm thick
10 cm for Brick / 10 Cm for Insulation / 10 CM for Blocks.
To save some space i am think of using 50 mm insulation boards.
so this way i will have double cavity wall 25cm thick.
10 cm for Brick / 5 Cm for Insulation / 10 CM for Blocks.
But i need your help to decide appropriate thickness of insulation.
I want to save space but i also want good insulation.
is 50mm thick insulation boards are sufficient for the walls?
