Hi guys
Can I ask if anybody knows how I can build the thinnest cavity wall to meet the required regs.
I am building a new lounge, and bedroom extensions on my single storey property.
The existing outside wall is faced concrete blocks which are about 100mm, with a 50mm cavity, and thermalite blocks on the inside wall.
I will of course be using faced concrete block to match the existing, but want to keep the overall wall thickness to the minimum.
The floor will have to be Block & Beam due to ground levels.
Any ideas if there is a super insulation, or new way of doing this.
I have had a problem with the build due to a drain that was 2.6m deep, running across where the footings go, so have had to go for mini piling (expensive believe me) had estimates ranging from £6000 to £17000 plus vat !!!
Also, any idea on how much I should be paying for a bricky to build the walls? One extension is 3.5m x 4.5m and the other is 3m x 5.5m
