I am building a porch in front of my recessed front door.
The current level needs to be increased about 240mm to match the indoor floor level.
I want to fit three LED lights in the new front of this area with the wires fed back through buried conduit into the house. The conduit will need to bend 90 degrees to follow the route into the house!
Sounds simple at first, until I discover that all the easily available conduit is 20 mm and that the rigid 16 mm oval does not seem easy to bend gently and uniformly into a long radius curve.
So any cheap small bore tube or conduit which can form a long radius bend?
Or any easy way to make the bend in the rigid 16 mm oval?
Tony
Tony
