Called a roofer from the local paper to move some mismatched tiles and to sort a weep around the chimney also to look at a leak in a valley that was replaced 10 years ago and to give the whole roof a look over incase of future problems,tiles were moved and valley done with some sealant? he said that it had a nick in it where the tiles had been cut and is not leaking now but the chimney is a different problem as it is letting a lot more water in than it was before,he said that he redressed the lead around the stack but from the loft you can now see daylight up the side,thinking that when he redressed it he opened up an exisisting split in the lead.
Bottom line is that i guess at least the lead on the sides of stack will want replacing possibly the front and rear skirts? could anyone let me have some sort of figure for a roofer to replace all the lead on the chimney,dont know if it makes a difference but we are a cm20 postcode and the chimney size is 28x41 inches.
