this device cannot load code 10
10 Dec 2005
Suffolk
hi all my system is an asrock mb athlon dual core chip vista premium 64 bit . ive just fitted a kworld dvb-t210se tv tunner pci card all was ok then it suddenly said no tunner card installed .reloaded drivers rebooted then ok , then got this message this device cannot load code 10 . it seems as if its a driver problem windows keeps saying the card is a Philips SAA713X, Hybrid Capture Device even though its a kworld one . any help welcome please
make sure you have the installation disks for the card first then,
Hold down the windows logo key the one next to the alt key and press the Pause break key,
select hardware tab,device manager,press + sign next to sound,video and game controllers to open up the device list,
look for your device has it got a red X beside it? If so right click , properties and select the device in window if not highlighted and press the remove button,
after it uninstalls, use installation disk to reinstall
the device isnt there or so it says tried loading drivers with device and windows replaces them
Have you checked that the device is compatible with Vista 64?
lol well the box has vista certified for windows vista on it ad there are 64 bit drivers so i would say it was or should be . i tried loading drivers from cd and now it says cant find device . its pushed well in pci slot too
had you removed the old drivers first, the ones you said were wrong?
tv tuners are always problematic for some reason. Have a browse through device manager for anything with a yellow exclamation mark. Or anything else that you don't recognise. It could be showing up as something else entirely, which if deleted will allow it to install correctly.
Do kworld have any tech support? Have you installed any other software/hardware prior to it going tits up?
i tried another pci slot tonight its working at the moment but im still holding my breath . it does say in the instructions make sure a mce certified dvd player software is installed on your pc whats that ?. i installed the mce encoder installer first as im using it with the windows media centre at the moment.
Yeh media centre will be mce certified (it stands for Media Centre Edition) ;)
