Have discovered there is a slow drip from this tap (photo taken from above) on my central heating pipes under the floorboards. It explains why the water pressure in the boiler drops periodically. Is it a drain valve and can I try and tighten the square nut or will it need replacing? Thanks
View media item 76988
