Thomas Dudley Vantage Dual Flush - no large flush
24 Dec 2004
Blackpool
Recently bought new house with one of these concealed cisterns. The small flush works every time, the large flush requires the button to be pressed several times to work.
Had a little read - someone mentioned "bellows" in the button - removed this but can only find a rubber diaphragm that runs in a plastic tube in the button assembly - all seems well - good "puff" of air felt at outlet. removed cover - shortened the plastic connecting tubes and excluded kinks/holes etc.
Still same issue - I'm assuming now a problem with the flush valve. It looks as though this can be removed via a service aperture at the front of the concealed cistern. Question is - are there any user servicable parts and if replacement is needed do I need to buy a Thomas Dudley one (with it being a strange concealed cistern) or would a better option be available (I read lots about "fluidmaster" on here)?
All help appreciated.
(It looks as though they don't leave much room to work - would prefer a normal cistern with a lid that lifts off!)
Fluidmaster do a flushvalve with either a 350mm or 550mm cable. If either of these are suitable, go for it.
