Thorn central heating boiler
17 Feb 2009
Sheffield
I have a thorn central heating boiler , when using water only the water is piping hot (reasonably quick) but when using water and heating it takes alot longer to get hot and also is not as hot. Water only does not work on gravity due to it being a fair distance away from the hot water cylinder so we had to have a pump fitted, could this be the reason why?
s plan? y plan? whats the stat on the cylinder set to wheres is it tied to on the cylinder? is it on cylinder or pipe to cylinder. does cental heating get hot? does central heating come on when hotwater only selected and vice versa
Nath
stat set at 65 and is strapped to center of the cylinder, when water only on the bathroom and one bedroom radiator comes on
yeah kev cheers for that mate u helped me out big time.. much appreciated mate!!
it seems that the motorised valve is passing.
Nath
we had the boiler moved 20 years ago, and the person did not put a motorised valve on it. We only have this problem in the winter because obviously we use the hot water and central heating together
