thorn house warmer
14 Aug 2008
Southampton
can anybody help me-got housewarmer mark2
I have tried to drain the system as normal from the last rad,but it won't drain.I have cut pipe under floorboard as advised and tried to drain that way,but the header tank still remains full.I have drained the header tank manually and then poured sludge remover in whilst it was filling up again,but nothing has happened.
please advise
regards
colin
You have a blocked cold feed . follow pipe from header tank to where it tees in it will be blocked around there
Thanks for the reply.I have followed the pipe and it comes down the wall of the house intothe boiler.Is this what you mean.
thanks
Very unusual if cold feed goes all the way back to a back boiler .
thats why you have no water in rads it cannot get there because of blockage in cold feed
thanks very much
ill try and get someone to help me out with
trying to clear this regards colin :oops:
