Hello,
The other day there were some workman outside the house replacing an underground power cable to my house which in turn supplies power to other houses in the street, these workman hit the gas supply to my house causing a small leak so they called the gas company to fix it..... I'll get to the point. Anyway, as i was about to go to work i decided to turn the gas of to the backboiler(fire) in fear of returning home to a house full of gas, the fire/backboiler is a Thorn Housewarmer 44-789-04 who's pilot light is always on, i turned the supply of to the boiler by pressing the red button bottom left hand side behind the plate, and on leaving the house i also turned the maim supply off to be double sure.
Ok, so my problem is getting the thing to reignite, its been two days now and i really need a bath ). I've tried turning the stat thats under the fire off and on but that didn't work, I've tried turning the stat off/on while holding the white button in that as a symbol of a flame on it, but that didn't do the job, and I've also tried turning the heating/water on with the stat off, then turning the stat back on...still no joy.
The fire itself works fine the pilot light to ignite the fire stays on, its just backboilers pilot light that's the problem.
The 3a fuse to the timer (Randall 103) controller is ok as i can hear the pump kick in when i turn it on.
Any help in getting this old boiler to kick back in would be much appreciated.
GSB.
GSB.
