thorn M gas boiler
31 Oct 2004
hi folks
yesterday my trusty old (must be 20yrs +) boiler wouldnt flare up,i turned the dial to number 3 but the flames didnt kick in...the piolet light is working fine...but the flames just aint kicking in
the hot water is working,so its just the central heating thats not.....when i turn everything on i hear the noise as if it is working but still the flames arnt flaring up,??
this has happened before and after havin a little mess they kicked in again (but cant remember what i did )
is there a proper way of making the flames flare up ie: turnin the temp control switchs first ect?
or do i just turn the boiler dial up and it should light up?
thx for any help
Nifty
hi kev
i can here the pump running it just wont flare up :(
anything esle i can try?
hi kev
yes the hot water was ok,although i think as we use it its running out and goin just warm
ive tried switching it all off as in resetting....but to be honest i could do with a manual of how to work this boiler out
ive just moved in and its the oldest boiler ive ever seen :)
thorn m
nothing to work out old workhorse
not the most efficient but a bl**dy good boiler
solenoid on the gas valve springs to mind :)
i dont wanna mess with it myself....im gonna have to call some1 out :(
cant work it out cause its done it before.......when i turn the dial which is supposed to boot it up i here a click but thats it.....still the spring valve?
how much am i lookin at? :(
cheers for your help
Nifty
hi kev
well its finally fired up
after breaking the knob by twisting it to far its working
could it still be the solinoid u said???????????
to make it light all i did was light paper and stick it in past the piolt light and it worked......maybe just luck?
maybe time i got it serviced....i noticed a sticker on there tellin me the last service date was 1987..... :)
thx for all your help
regards
Nifty
