Hey all,
We're having a 30sqm garden office built in January which will be used 6-8 hours 4-5 days a week. It's going in very near an existing A2W heatpump with plenty of extra capacity, so the plan is to put in UFH.
I'd like it to be as comfortable as possible without going totally overboard. In starting my research I came across the merits of warm flat roofs, so we will build it that way (EPDM on top of 100mm PIR then another 100mm PIR between the joists with various OSB and membranes sprinkled in there appropriately). That journey lead me to the concept of warm walls, again with the purpose of removing the cold bridges caused by the stud timbers.
So I wonder does anybody have input on the below drawing I put together? The areas I had concerns as I drew this were -
1. I need to add OSB to the outside of the studwork to strengthen it, but should I then be adding another layer on the outside of the external layer of insulation to give the cladding battens something firm to fix into as shown in the drawing?
2. Does the breathable membrane need to wrap in and under the external insulation and effectively meet the DPC or is there no need given the cladding will protect everything down there from rain?
3. I haven't drawn in how the sole plate will be fixed down to the foundations as I've read lots of the options and wonder what is the most practical to build. Can the builder just drill down through sole plate and put in something like 300mm concrete/masonry screws or expansion anchors or is that likely to split those blocks?
4. Does there need to be another 150x44 timber on top of the sole plate for the studs to be built on?
A builder + carpenter will be doing the build not me, I just enjoy nerding out on this stuff and I'm conscious they may not be too familiar with the warm wall concept so it would be safer to have a drawing I can hand them.
Any and all thoughts appreciated!
