We're getting quotes to have a conversion to a combi boiler, replacing the old boiler in a slightly oversized kitchen cupboard. We've had quotes for a 34 CDi Classic, and a 36 CDi Compact.
The Compact would fit straight in the cupboard without modifications. The Classic would require some modifications to the cupboard to bring it out a bit, and would leave it looking worse off (and worse case removed - which I really don't want), so here the Compact (which I'm leaning towards) would be much more suitable.
On paper it seems the Compact is marginally better on the hot water (14.7 l/min compared to the Classic's 14.3 l/min). However, the Classic seems to have heating up to 30kW vs the Compact's 24kw
The Compact at least would be installed by a WB approved installer, so would come with a 10 year warranty (as I realise would the Classic if I use an approved installer).
My main questions are,
Whilst I realise there are other great products out there by manufactures beginning with V, I'm pretty much decided on WB (as I can't face starting this process again!)
- is the extra 6kW of heat the Classic can use of significance (20 year old 4 bed detached, 1 bathroom + 1 en-suite with shower, 11 med-small rads)?
- Are there any major other differences between the boilers I should be aware of.
- Is the Compact as good as the Classic?
