bit embarassed to ask-but here goes-what is going on with a three port Danfoss which doesn't return to hw only when "asked"? Replaced actuator,as I had done about 15 months ago,and all working.Checked hw off wire goes to grey actuator wire and all ok.
The grey wire ( I believe ) stalls the motor when live,so when hw on at programmer,this voltage on the grey wire is not present,allowing the return spring to take the valve motor to the rest position-ie hw.
The fault was showing up as a call for hw only sending heated water round the radiator circuit.
Also this problem only occurred after a ch only demand-mid way operation was normal
The wiring looked to be correct,and as I say a new head sorted it,but I,m concerned about the short life of the valve,and what failed and why,presumably the diode is ok as the mid position operation was normal,maybe a programmer fault-hw off voltage not turning off when hw on called for at programmer?
Sorry for long post-I suspect I am missing something blindingly obvious
